BUG: Performance in zoomed mode in IDE
@rolfk wrote:
I seem to have remembered something wrong. The VI coordinates still seems an i16 but the absolute screen coordinates is an i32.
Not that I ever felt like getting rilled up about the i16 limit for Vi diagrams and even less about frontpanels. Anyone creating such VIs should be forbidden to use LabVIEW. 😀
You might not always know that you, or anybody else (accidentally) has offset the VI's origin.
If the origin isn't 0,0, but 32k-1, 0, even a tiny bit of code can become a problem.
I think the only way to test\prevent this in the IDE is to regularly do QD+CTRL+O.
Message 31 of 33
(411 Views)
New find!
If you have several windows open, it gets horrible even without Navigation window. It's actually slightly faster with it open?!
It's every 2nd update that's extremely slow.
I added an Iteration indicator connected to 'i' and noticed a new behaviour.
1. Having 10 windows open, i got 3700 ms update time at 106% zoom even without Navigation window (only 1 window zoomed, i haven't tested with several)
2. Opening Nav. actually dropped it to 2700 ...
3. Looking at the Iteration, it seems to be fast/skip every second. I only saw the big time numbers, but 'i' jumped from 151 to 153, 155 and so on, so every 2nd must have been fast/skipped.
Qestit Systems
Certified-LabVIEW-Developer
Message 32 of 33
(379 Views)
It seems to be fixed in 2024.3.2f2
They seems to only use the last movement now, shift-moving stuff doesn't queue up.
Qestit Systems
Message 33 of 33
(264 Views)
