06-16-2015 11:31 AM
I was creating a simple VI to serialize an I32 array to bytes and ran into this interesting bug. This code is being run in 32bit LabVIEW 2014 SP1, fully patched. Save the two attachments and run TestI32ToByteArray.vi. Note that the 6 and 7 at the end of the array are reversed. If you probe around, the data all looks good, except the split string on the final low word is reversed. Any ideas?
More details on setup:
LabVIEW 2014 SP1 32-bit
AMD FX-6300 3.5GHz hex core processor
Windows 7 64-bit, fully patched
8GB RAM
Solved! Go to Solution.
06-16-2015 11:39 AM - edited 06-16-2015 11:40 AM
Check your wiring, the 6 is wired to the bottom terminal of the join, and the 7 is wired to the top.
Get going with G! - LabVIEW Wiki.
17 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
06-16-2015 11:40 AM - edited 06-16-2015 11:41 AM
06-16-2015 11:44 AM - edited 06-16-2015 11:44 AM
@jcarmody wrote:
<edit>I lost the race to Hooovahh<\edit>
Wuah haha ![]()
06-16-2015 11:59 AM
I obviously need to drink more coffee (or less
