BUG: XScale.Multiplier is not working (LV 7.1.1)
I found a very strange workaround, at least for indicators: if the data is wired to a local variable instead of the terminal, the indicators look well.
This is strange and i did not found any document explaining this in detail.
Message 11 of 12
(587 Views)
Property modes DO NOT WORK in LV RT when no display (remote or local) is activated.
I've spent a hundred hours figuring this out the hard way -- you'd think that all the objects would point to a NULL device and allow the LV programmer to read/write properties and expect that what is written can be read back -- but NOOOOOOOO -- not LabView.
I've never liked LV hardcopy output, I got around these types of problems by using TeX and PS -- beautiful results AND portable.
...Dan
Message 12 of 12
(578 Views)
