BUG report
Hi Ni,
Please see attached picture for simple comparison of 2 strings.
Why this didn't work?
Compare FF55 2A00 with itself and cannot get correct result.
Thanks.
Thana
(3,237 Views)
Refer to this document.
Aarthi
(3,229 Views)
It doesn't work because you can't use a null character in the pattern - if you want to search for that the pattern needs to have "\00". I don't usually use this, so I don't know why this is like that. Read the help for more details.
In general, there are much better ways of sharing screenshots than taking a picture of the actual screen. The Code Capture Tool is very convenient for LV, but you can also use the printscreen key on your keyboard and Paint.
___________________
Try to take over the world!
(3,227 Views)
Hey Thana,
I ran the same code on my computer and didn't have a problem. See the attached screenshots of my front panel and block diagram.
What version of LabVIEW are you using?
Rachel D.
(3,170 Views)
