BUG with File Path Browse Button
I think this bug may still be in LV2018SP1, having this issue with an exe, had to do a workaround.  It was easy but annoying. Common guys, do better
Message 11 of 12
(1,944 Views)
I would bet it’s not classified as bug by NI but functioning as intended as browsing into a packed library is not something you usually end up doing in an executable and that code is intentionally removed in the runtime engine.
If this is a good decision is another matter but definitely a valid one. Calling it a bug is therefore not likely helping. Arguing with good examples why you should be able to do it might be better but personally I think letting a user select which exported VI to execute from a packed library isn’t exactly a user friendly and safe interface.
Rolf Kalbermatter  My Blog
Message 12 of 12
(1,914 Views)
