Backslash Codes Display
I am not able to use all Display Codes.
For example a string Hello\b is shown as Hello
or Jump\fin\s\the\sfire is shown as Jumpin the fire
The linefeed\n is working but the carrige return\r also works like a line feed.
(2,881 Views)
I think the only problem with the two \ characters you mention is that there's no representation for them in the font that you're using. If you really need to see them as opposed to send control codes to some device, try a font like Terminal.
(2,881 Views)
