Bad LV driver template
Why is this still in the LV driver template?
At least they are not stacked on top of each other like they usually are in this one. 😋
agilent_3446x_series driver if you are interested. Specifically the "Public\Utility\Error Query.vi"
Former Certified LabVIEW Developer (CLD)
Currently using LabVIEW 2022
(545 Views)
At some point, the Merge Errors was changed from a VI to a primitive (or maybe an XNode). The stacked up Merge Errors is an artifact of the conversion code. I would guess the cascading Merge Errors is from somebody just using the Diagram Cleanup and not looking at the results.
(493 Views)
