Bad VI from ni.com - Managing Buttons - Help Please
I downloaded a vi from www.ni.com/support/
http://zone.ni.com/devzone/explprog.nsf/6c163603265406328625682a006ed37d/c74b59054502fa0586256854006490d8?OpenDocument
The vi gives a demonstration on how to make one button turn off when
another button is selected. Well, the VI works great for only 4 units,
but when I make the array sizes for 5 or more units, the sub vi
doesn't work.
I put probes every where, but can't find the problem. There seems to
be a 'default' setting to 4 buttons when the vi goes from "Manage
Radio Buttons" to "Simulating Radio Buttons".
I would like this option, but now I'm more stumped at this problem
than anything.
Thank you for your time.
-Dorian
(2,680 Views)
The only changes that need to be made are:
1. Change the array size input to the Initialize Array function to 5
2. Add another Option button (set its mech action to switch when released)
3. Change the size of the Array to Cluster function to 5
4. Create a local variable for the Option 5 button and wire the same as the
first 4
It appears to work for me after making these changes. The Manage Radio
Button SubVI dynamically changes its size, so no modifications are
necessary.
You can also customize a slide control to work like a radio button control.
It takes a little patience, but the result is a radio button with only a
terminal on the block diagram.
Mike
"Dorian Grey" wrote in message
news:bbe7c0b5.0201122221.7bfd1f5@posting.google
.com...
> doesn't work.
> than anything.
> -Dorian
(2,680 Views)
