Bad reference error using "Clear PDA Chart"
Hi everybody,
I'm using the "Clear PDA Chart" function to clear a Graph on a PDA appplication (the function should clear both graph and chart)
I' using a reference as input of the function, but it does not work and I get the error
"App failed. Error code 260055065. The control ID is incorrect and does not refer to a graph or chart." when I try to clearand the application crashes.
I can get the reason. Any clue?
I'm attaching the code.
G.Paolo
(2,611 Views)
you are right, it is a known issue, probably it will be fixed in next release.
Sorry for this.
NicolaC.
(2,595 Views)
