Bandwidth of DataSocket
I am using DataSocket to publish some data. Does anyone know how can I see the bandwidth used by DataSocket?
(2,699 Views)
You could have a look with a sniffer like ethereal.
The used bandwidth is normally not very high, but we expirienced that there are many many small packets sent over the network if you use datasockets. So in heavy communication with fieldpoint system we had problems with cheap switches inbetween the fieldpoint system and the main pc not because of the bandwidth usage but because of the high packets traffic!
(2,689 Views)
