Barcode Reader Using Zxing .net
I have tried reading bar code using Zxing as some of the bar code formats were not available in "IMAQ Readbarcode2.vi" . got help from - https://lavag.org/topic/16964-barcode-decoder-by-using-labview/
finally able to read bar code but can anyone help for setting the specific format, as physical setup have specific type of bar code and setting earlier would decease the time taken to decode. i have attached my code if anyone need reference.
you going to need file "AForge.NET Framework-2.2.5.exe" from
http://www.aforgenet.com/aforge/framework/
For Zxing.net library
https://github.com/micjahn/ZXing.Net/releases/tag/v0.16.6.0
code-
Message 1 of 1
(2,921 Views)
