Barcode scanner key focus
Hi All
I have doubt in setting the key focus to the string.
Once i started the program, message pops up to the user.once the user clicked OK button the cursor have to come to string. I have attached my VI.pls give me some guidance
(3,819 Views)
Hi Veeru,
do you really need the PopUp every loop iteration? I made some changes in your vi, maybe it helps.
You should define an  event case for every Control you want to work with.
Mike
(3,804 Views)
Thanks Mike
I tried this example, but still i have same problem(cursor doesnt come to string box).
(3,792 Views)
Having a sepate popup when the bar code scan is itself a popup seems a bit silly.
(3,783 Views)
