Base64 to image
I convert Image to base64 from website and I would like to build program in labview to convert base64 to image. do you have solution to do ?
(4,194 Views)
I think a better question is, "Why do you want to do this?"  Usually when someone wants to do something odd like this, it's only because they don't know there's an easier way to do it.  🙂
You can read a picture directly with LabVIEW using Read JPEG File VI (or the appropriate VI on the same palette) which converts it into something LabVIEW can easily manipulate.  I hope this helps.
Bill
CLD
(Mid-Level minion.)
(4,172 Views)
There are VIs for decoding Base64 data, but as Billko said, why bother with the conversion? You can read images directly using the LabVIEW HTTP client VIs.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(4,131 Views)
