BaseCam SimpleBGC 32-bit controller AND ARDUINO or PC card COMPATIBILITY WITH LABVIEW
Why use an arduino instead of free mentioned ttl adapter that you would connect directly to the pc?
The code could be modified to work with an arduino.
Message 11 of 14
(1,667 Views)
is it possible to connect the Adafruit direct to pc?
do i have to build a RS32 connection or USB connection? How can i do it?
or is it only possible to connect to arduino card and then arduino to pc?
Message 12 of 14
(1,645 Views)
Please pay attention. The link you provided says that you can add a ttl to RS232 converter. Up to you.
Message 13 of 14
(1,636 Views)
TO sum up:
Adafruit ultimate GPS breakout 66 channel
and the USB to TTL serial cable debug / console for Rasperry Pi .
And i connect direct the GPS to my computer. then can i work with LABVIEW?
because in other websites tey use an arduino uno or a Raspberry Pi Model B 512MB RAM why? because they don't want to work with LABVIEW ? is it true?
Message 14 of 14
(1,607 Views)
