Baseline and Property Node
Hi Folks:
I have a baseline plot that is plotting on my Waveform Chart as shown on the attached vi.
I want to have a Boolean button on my Front Panel that I can click to make the Baseline visible, or not visible on my Waveform Chart.  How do I code that on my Block Diagram.
I appreciate any help.
Thanks.
(3,137 Views)
Same project with similar issues.  You recommend you keep all of this in a single thread.
http://forums.ni.com/t5/LabVIEW/Programming-Multiple-Plots-and-Baseline-on-Waveform-Chart/m-p/306684...
(3,123 Views)
Well, it may be same vi, and that is because am trying to code my application and using the same vi to illustration my question better.  Certainly, not same issue.
Thanks for your comment tho.
(3,112 Views)
