Basic DAQ Question with OPC UA
Hi All,
I'm very new to Labview and am trying to set up an OPC UA server. I followed the steps here (https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x2CMCAY&l=en-US) to create a shared variable, then realized shared variables aren't compatible with OPC UA and only with OPC DA.
So, then I created the OPC UA server, and a read and write function, using this tutorial (https://www.youtube.com/watch?v=AoneC2cSzto&t=2251s&ab_channel=IndustrialITandAutomation).
Now, all I need to do is push data from a DAQ analog input to the OPC UA server. I've tried to do it shown below circled in red, however I am not seeing any of the data show up on the OPC Read VI. It is showing up in the "Numeric" box in the client VI, however, so I know the DAQ is reading the voltage input properly. Any help with what I'm doing incorrectly would be greatly appreciated! I really don't know where to start. Thank you very much.
(1,843 Views)
Would it be possible for somebody to please answer the above question? I'm looking for the same answer and cannot find any other information on transmitting DAQ waveforms through OPC UA.
Thanks!
(1,725 Views)
