Basic Function Generator does not return current time stamp
The Basic Function Generator .VI file does not return the current time stamp.Instead it counts from 1904.
Is there a solution to this so that the basic function generator returns a current time stamp?
(3,444 Views)
Other than changing the internal code, NO. The timestamp is relative to the start of generation. I see no reason to have absolute timestamps as you don't know when a sample was actually generated untill you've measured it on the ouput.
André (CLA, CLED)
(3,441 Views)
"Is there a solution to this" ...  yes, if you expand that to include "workarounds":
(3,437 Views)
In this way the timestamp between generations is not continious.
Only do this for the first and for subsequent generations add the amount of time generated.
André (CLA, CLED)
(3,411 Views)
