Basic Level Trigger Detection and While Loop Condition
You can use an Or node to perform an OR operation on your boolean that you write to the Stop terminal. Make the OR condition True if trigger is True, or True if total # samples has reached 10k (or you can base it on the number of iterations, or a timer, or many other things).
Cheers
Message 11 of 13
(1,382 Views)
So simple it might just work -- I'll let you know
Thanks!
Message 12 of 13
(1,379 Views)
Here's what I mean.
Cheers
Message 13 of 13
(1,376 Views)
