Basic Newbie Question
Hi, I am trying to add a light display to indicate when a certain portion of my code is running. Basically, I need to know how to turn on and off a single boolean indicator within a flat sequence structure. Any help would be appreciated. Thankszzz.JPG
(4,547 Views)
Accepted by topic author DoomPirate
Hi DoomPirate,
place your indicator in the first frame and a local variable or an property node of it in the last.
It's also possible with only the indicator if you use a statemachine architecture.
Mike
(4,536 Views)
Thanks mike, It worked. I went with the property node route. I wasted 5 hours trying to get it to work last week. I had a major headache.
(4,521 Views)
One thing you can try now, which is quite beutiful code:
Make a while loop
Create a led indicator
Connect the indicator to the while loop and make it a shift register
/Y
Qestit Systems
Certified-LabVIEW-Developer
(4,497 Views)
As a basic newbiew, you make the mistake of sequence overuse. They are very rarely needed. You should always think in terms of a state machine.
Here is a very simple linear two-state machine that duplicates your code quite accurately. As you can see, no sequence structures, local variables or property nodes are needed.
Here's another big beginner mistake. In simple cases like this, you should always pick a local variable over a value property node. Property nodes are literally orders of magnitude more expensive. Property nodes should only be used if really needed (e.g. access an element inside a cluster or in another VI).
Message Edited by altenbach on 06-29-2009 09:08 AM
(4,482 Views)
