Basic Stamp 2 MicroController
please can you explain further.  the Stamp code is designed to echo a response at the same time as carrying out the action. If you read an input eg I1 you will get the pin status.
I think you need to add some more indicators to your code and have a careful look at exactly what is going on. I am sure it will become clear if you examine the strings sent between labview and the stamp, and look at the code which generates the strings.
Best of luck,
Michael.
Message 11 of 11
(435 Views)
