Basic Timeout Newbie Question
So it just braodcasts the data?  I would try something like adding a serial poll to make sure the bits are there.  Also note the initialization of the shift register.
Message 11 of 18
(1,452 Views)
lol, I have labview 8.5, do you mind saving it in a lower version? thanks!
Message 12 of 18
(1,449 Views)
Accepted by topic author DoomPirate
Message 13 of 18
(1,446 Views)
Basically, I am performing 300 read attempts from the device. Outputing a blank string if nothing was found, and outputting valid data if the read was sucessful.
Message 14 of 18
(1,446 Views)
I think Im sort of on the right track using your method. I'm gonna tackle it again in the morning.
Message 15 of 18
(1,438 Views)
Is there any reason behind 300 reads?  Or do you want to just read until you get a valid answer?
Message 16 of 18
(1,417 Views)
We've given up on this particular temperature probe. Its very unreliable. Instead we are gonna use a Fluke GPIB multimeter and use some analog circuitry/labview to make a .01 degree accurate thermometer. Thanks for all the help jack.
Message 17 of 18
(1,406 Views)
I havent looked at the problem in much detail but would it be possible to get a GPIB driver for the piece of equipment that you use. They would have pre-built VIs which would have error handling and it may work.
It would just stop you from sweating around looking for a problem in your code...
Message 18 of 18
(1,375 Views)
