Basic structure for sequencial control
Dear all,
I'm trying to create a vi to realize sequencial execution of subvi's, the time delay between two subvi's should also be controllable. Is there any sample program available? Thanks
Jerry
(3,027 Views)
Search here for "state machine" 🙂
(3,022 Views)
Also look under the Help menu, find examples. and search for State Machine
There are empty templates available if you look under the Files Menu, select New > From Template>
You'll see a list, such as Event Structure, with data, etc and State Machine.  There should be 2 of them.
As Altenbach suggested, do a search in this forum for State Machines.
They are easy to implement, easy to use, easy to maintain, and are scalable.  Use Type Def'ed control for your case selector, you'll thank me after you modify it's content for the 10th time 😉
RayR
(3,019 Views)
