Basics 2 CBT - Requires Acquire Signal.vi - not on disk
I am working through the LabVIEW Basics 2 Computer Based training, and exercise 4-1 calls out for Acquire Signal.vi. The manual states that it can be found in the user library, under Basics 2.
This is not the case! It is not included on the CBT disk with the other examples. Can I be sent a copy of this VI please?
(3,051 Views)
In addition to installing LabVIEW eval, you also have to install the Basics2.llb.
The instructions from the ReadMe file:
"Copy the Basics2.llb file from Course Disc 1 to the labview\user.lib directory. This is usually stored in [drive letter]\Program Files\National Instruments\LabVIEW\user.lib."
To make the Basics2.lib show up under the user.lib on your functions palette, please review the following KnowledgeBase:
How Do I Add Custom SubVI to the Functions Palette?
Also, make sure that you have DAQmx installed. The LabVIEW Evaluation Version gives the option of installing simulation DAQ VI's. If the complete install option is chosen, the simulat
ion VIs are installed.
To avoid this, choose a custom install and don't allow the Evaluation Version to install NI-DAQ. After the LabVIEW Evaluation Version is installed, install NI-DAQ and include support for LabVIEW 7.0. The DAQ VIs will now read data from your DAQ device. There is a link to the NI-DAQ download page below.
NI-DAQ Driver Support for Windows
Zvezdana S.
(3,051 Views)
Thank you.
(3,051 Views)
