Basler acA 1300-60gc
Hello, I have camera Basler and I´d like to get number of Resulting Frame rate to Labview. I don´t know how. I use property node for active attributions and that works only for attributes which are not grey colored in NI MAX.
Can anybody help me please?
thanks
(4,025 Views)
Ha, I found it .
(4,021 Views)
can You share the solution with us in case that someone else is going to be in the same situation?
(3,987 Views)
I used normally property nod with active attribute and U32 value, but name of active value in LV is little bit diffrent than NI MAX - same words but together and without the brackets.
(3,967 Views)
(3,940 Views)
Hello
I'm developing an application with the same camera. My question is, how do you connect the camera? Which are the physical connections that you made?
The trouble that I have is that my Measurement & Automation Explorer does not recognize the camera...
(3,789 Views)
First : I did basic configuration by Basler Pylon . That recognized my camera and I tried some configuration.
second: I think that you have to instal vision acquisition software to recognize camera.
(3,778 Views)
