Basys 2 FPGA board
Hello.I have basys 2 fpga board but I can not communicate to program this board.And I cant not is in the target and devices section.If you know the reason please help.
(4,530 Views)
Hi tahatas,
The LabVIEW FPGA module supports all NI FPGA targets.
Does that "basys 2 fpga board" belong to them?
(Do you even have LabVIEW/RT and LabVIEW/FPGA modules installed?)
(4,516 Views)
(4,510 Views)
Hi tahatas,
no need to start one more thread for the same topic!
(Not to mention that 3rd thread in the Turkish forum.)
(4,502 Views)
 I already have labview/fpga but I dont have labview/RT.Because Labview/RT  compatible with 32. Mine is 64 bit Is there any other solution for this?
(4,498 Views)
Hi tahatas,
  1. I recommend to use LabVIEW/32bit with LabVIEW/RT and LabVIEW/FPGA module. (I have not switched over to 64bit LabVIEW environment.)
  2. Again the same question: is this "basys 2 fpga board" supported by LabVIEW/FPGA at all?
(4,491 Views)
Digilent boards (which is mine is also one of them) does not work with labview. Only the Interface for Adept by LabVIEW MakerHub provides an easy-to-use API for communicating with Digilent FPGA Boards.I will  try  this interface as well.Thank you for your answers and question.
(4,448 Views)
