Baud Rate Change with VISA
I'm using LabView to controll a spektrometer through the serial port. I
use VISA for the communication with the device. Unfortunately, the
device is always in 9600baud mode after power on. So I have to change
the baud-rate each time by a command i send to the device. So I open a
VISA session in 9600 mode and communicate with the divice to set it to
57600baud. After that, i have to reset my local serial port to the same
baud-rate. I do this with an property-node, where i change 'Serial Baud
Rate'.
Unfortunately, after I did this, the vi's that want to communicate after
the reset of the baud-rate stop with an error:
-1073807298
VI_ERROR_IO
Could not perform read/write operation because of I/O error.
(I try to write to the s
erial port after change of the baud-rate)
I would be very glad, if someone could give me an advice, why it doesn't
work, or how to make it work.
Thank you a lot.
Matthias
(3,869 Views)
Matthias Müller writes:
> Hello,
> Rate'.
> -1073807298
> VI_ERROR_IO
> (I try to write to the serial port after change of the baud-rate)
> Thank you a lot.
> Matthias
Matthias,
my first approach would be to close the first VISA session after the
property node. Data dependency is achieved by the error cluster feed
into a new session with the new properties.
IMHO you've discovered another bug in serial VISA.
HTH,
Johannes Nieß
P.S:What brand/modell of spectrometer are you programming for?
(3,869 Views)
I got it now :))
I tried first to close the session and and open a new one with the new
properties. But trying to open a new one always ended in a program error
of LabView and it closed with somekind of windows error (don't we all
know them!?). So I tried something else. My spectrometer (a ccd-array
spektrometer from LASER2000 with 2048 pixels) just uses a serial-port,
so i changed the VISA-Session-Node to 'Serial Instr'. This was all, and
now I can switch the baudrate with the property node very well 🙂
So thank you for your advice anyway.
Matthias
Johannes Niess wrote:
> Matthias,
> into a new session
> HTH,
> Johannes Nieß
(3,869 Views)
