Baud rate sample rate
The short answer is I have a requirement to read/sample every 10 ms.  Trying to explain to the user that I have to display it at that rate too if they'd like real time data.  I put a case stmnt in my loop to display the data every 50th iteration ( user selectable) of the loop, that slowed the display down a litle but added over head to my reads.  I think I'm going to pursue Wayne's suggestion.
Message 11 of 15
(955 Views)
Thanks...that sounds more robust.  I wasn't aware of that solution on the Read Write Visa until you pointed it out.
Message 12 of 15
(953 Views)
Richard
Message 13 of 15
(943 Views)
Scary part is that I can remember when that show first appeared on TV.
Message 14 of 15
(939 Views)
It sounds as though Wayne's solution is on the right track. Let us know if that works for you, Mark!
Peter E
Message 15 of 15
(933 Views)
