Baud rate
Hi All,
I am working on CANOpen protocol, In one of the application I have to change the baud rate twice.
The whole application is like this , I have a Motor control drive, the initial baud rate of the drive is 250, CANOpen is used for communication .
I can change the baud rate once and can check communication in drive by accessing some of the parameters, after this I again changed the baud rate to some other value and when i try to check the communication , I am getting CAN Interface create error.
This is the problem i am facing.
(2,948 Views)
Do you close the port inbetween the baud rate changes?
André
André (CLA, CLED)
(2,936 Views)
