Beep
I know that the Beep.vi only works on the MAC and doesn't work under MS Windows but how about LINUX? The program that I'm writing will be running in LINUX but I'm developing it under MS Windows. Just wondering if it's worth putting it into the product.
Thanks in advance.
-Tom
Thomas L. Byers
tomb@first-sys.com
http://www.first-sys.com
First Systems Corporation, Inc.
4 Chatham Court
Westerly, RI 02891
(401) 348-0542
(3,067 Views)
The Beep.vi will perform the same way on LINUX as it does on Windows. You will only be able to produce one type of beep. Macintosh is the only platform that will not ignore the frequency, duration, and intensity inputs.
Matt Kisler
http://www.ni.com/ask
(3,067 Views)
