Beginner - Text file configuring display element
Is it possible to use a text file to configure the properties of a element that is showed in the front panel?
Thank you in advance
(3,348 Views)
In the file IO palette you can find a sub palette for configuration files. Using this vis you can create, read and write ini-files.
Using LV8.0
Don't be afraid to rate a good answer... 😉
(3,347 Views)
It works perfectly.
But, if I want to create a new element (for example: display a new graph), is it possible to do, getting the properties of this displayed element  from a text file?
Thank you in advance.
(3,330 Views)
You cannot create a new object in a running VI.  If you want to create a new object in a VI and then dynamically launch that VI, you will need to use scripting.  presently scripting is unsupported and unreleased.  That being said, the LAVA folks have a nice discussion group on the topic.  It is here: http://forums.lavag.org/index.php?showforum=29
I hope that this helps,
Bob Young
(3,323 Views)
...however you CAN use a property node to make an existing graph visible or invisible under program control.
(3,309 Views)
