Beginner help: export a multichannel Arduino analogue input to a single csv
Hello all. This is my first forum post! As a newcomer to LabVIEW, I'm really impressed by its functionality.
I'd like assistance with teh following apparatus I'm using:
  • I have a four sensors that each output an analogue voltage.
  • These input to the "analog in" pins of an Arduino Uno
  • The waveform chart & grpah on my front panel both display as expected
The problem is: how can I take the array accumulated to produce the (correct) waveform graph to a csv file?
I want this format csv file:
Time,Voltage1,Volatge2,Voltage3,Voltage3,Voltage4
06/03/2018 17:50....,2.089,2.3,3.435,1.5898
...... etc etc
BUT I only get:
Time,Voltage1,
06/03/2018 17:50,2.435
06/03/2018 17:51,2.222
........etc.........
I have tried with the waveform datatype, but can only get this to work for a single voltage channel. I've atatced screenshots of the block diagrams to assist. Many thanks in advance.csv saving attemptcsv saving attempt
(3,446 Views)
Hi mb,
you write to the Y input four times: this way you overwrite the same data three times...
You should create 4 waveforms instead! (Create an array of waveforms.)
(3,441 Views)
Thanks a that. Please elaborate on the array part: do I then createna single array from these 4 waveforms?
(3,429 Views)
Hi mb,
yes...
(3,419 Views)
Don't write the waveform data directly to a file.
Build an array with X,Y1,Y2,Y3,Y4  as the columns and use "Write Delimited Spreadsheet.vi" to write the array to a file.
=== Engineer Ambiguously ===
(3,395 Views)
