06-25-2007 03:22 AM
Dear RobC,
I know this thread was created some time back. However could you please explain how you successfully did your connection to remote MySQL database ? It will help me a lot as I have to conenct to a MySQL database in a remote server and insert records as part of my project. The worst part for me is that I am using SQL for the first time. Thanks in advance!
Deepu. Using LabView7.0, 8.2.1
06-25-2007 07:02 AM
06-25-2007 08:18 AM
01-10-2008 12:08 AM
To RobC :
Now, I'am facing the same puzzle you have met, would you please share the connectionstrings setting in labsql to connect to the remote MySQL server?
01-16-2008 05:53 AM
03-28-2008 03:15 PM
03-28-2008 11:54 PM
03-31-2008 02:17 AM
CHAR columns to full column length.10-04-2010 05:40 AM
Hi Bill,
Can you explain in more details regarding
step 2. Create a DSN using the mySQL ODBC driver and configure it to point to your network based server. (in WinXP: Control Panel->Administrator Tools->Data Sources (ODBC)).
Anyone please help me to guide me in details on how to setup a remote database for Labview?
Im using Labview 8.5 with database connectivity tools.
I've tried to insert and create table using MS Access and it works.
Now i wish to store my data in a remote database.
Can anyone guide me ? I dont know how to setup a MYSQL database
09-13-2012 09:58 AM
Hi Ben
Compile Worker can be launched manually and it will ask to choose between local and remote compile server as normal if we launch the compiler configuration window.
Best Regards
Anders Rohde
National Instruments Denmark
