Besst way
What is the best way to do this i Labview:
- combine multiple diffrent signal(boolean type - 0,1) to data logging
- then from this "data log" do some "background" calculation(in labview)
I was looking something with "Collector", "write to measurmetn"... is this easiest way; any advice please?
thanks
_________________________
Rookie; LV 2011 on WIN 7
(3,123 Views)
Any idea, advice... on that?
(3,093 Views)
Your description is way to vague to give any specific advice.
(3,078 Views)
OK. let's say, I have some input data(real signal from one process) which I must save to some sort of "data base". This could be an .txt or excel file whatever. In background of running this process I must calculate some values for example average, and time production, after that I will also add some graph(for analyse)..which I like to calculate from this already saved "data base". Now I'm searching for tutorial or any advice how to do this at easiest way?
I hope that now is more clear what I want to do.
(3,075 Views)
Hi hlod,
There are still a few things that could do with clearing up:
- Where is your input data coming from?  What hardware are you using?
- Have you considered analysing the data before it is logged?
Everything you have eluded to sounds like it could be achieved using Express VIs - these are configuration based so the coding is minimal.  There is a tutorial which builds up an example of analysis and logging of a simulated signal - although you could adapt this using the DAQ Assistant to use real measurements from one of our data acquisition cards/devices.
Depending on your level of experience it may also be beneficial for you to have a read through the Getting Started with LabVIEW literature.
Peter D
(3,061 Views)
well none of your link not working for me;
Input signals are digital and comes from PLC (OPC server)
I need analysing from data which I get from whole process, also need to make some history, so i can choose for example how mayn pieces was created 3 days before, what was average of product, time to make one piece...
thank you.
(3,043 Views)
Hi hlod,
All the links work for me - have you tried again today?
Using OPC servers to speak to a PLC is a different discussion - what have you achieved so far?  A quick search of NI.com, and the Example Finder in LabVIEW (Help > Find Examples...) should get you some resources to get started.
Peter D
(3,015 Views)
