Best Method To Use a RunTime Menu
Hi
I´m using a menu in my LabView Apllication, and I saw today that it takes considerable ressources. I enclose a vi in order to explain better what I mean. with my menu activated, my program loop runs about 5 times per sec, and about 170 without. Do you have better methods to use a RunTime Menu ?
Thanks in advance for your help
Nicolas Minary
(3,108 Views)
Sorry, I forgot the vi...
(3,108 Views)
Your VI runs in an all out loop. Use a function called wait(ms) in the loop. It is on the funtions >> time and dialog palette. I figure ms waits of 200 or 1/5 of a second is enough to make the front panel respond to the user smoothly.
If you have LabVIEW 6.1 or 7 you can use the event structure to handle your menu button clicks. This is the best way to free up computing resources. The LabVIEW shipping examples certaily have event examples but I think there is also a menu example as well.
(3,108 Views)
