Best NI software versions for NI USB-6211 and Windows XP SP3 version 2002?
Hello everyone,
I have a NI USB-6211 and my pc has windows XP SP3 version 2002. I was wondering which LABVIEW and DAQmx versions will be best for my current configuration. Since I am totally a newbie to connecting these kind USB devices to PC for data acqusition purposes, I would really appreciate on suggestions, that what other NI softwares I would need other than LABVIEW and DAQmx in order to connect NI USB 6211 to LABVIEW. I want to measure some voltage signals through NI USB-6211.
Perseus
(2,962 Views)
As I mentioned in your other post, you can download 2010. It should work just fine. Also dowload the latest version of DAQmx.
You should not need any other software based on what you have described.
(2,958 Views)
Thanks Dennis for your reply.
You said that I should install the latest version of DAQmx, i think the latest version of DAQmx that is compatible with LABVIEW 2010 is version no DAQmx 9.1.7. What do you think,which DAQmx version I should use?
_Perseus
(2,954 Views)
As I said, click on the 'Support' link at the top of the page. The latest DAQmx is 9.3.
(2,950 Views)
