Best Practise for connecting to Ethernet based device
I have inherited a system where we have a cDAQ-9181 controlling an vehicle access barrier, with a LabView application on  a PC talking to it via Ethernet.
(The application is very simple - press a button > send a value to the 9181 unit > opens the barrier )
All works fine most of the time.
( We occasionally get network related errors. The LabView application sometimes thinks another PC has reserved the unit, or gives “error 89130 - device not available for routing” )
The users would now like to be able to easily run the application from a second PC ( not at the same time ), but this seems to be a problem. If I exit the application on PC “A” and run it on PC “B” it struggles to reserve the chassis, and throws the “89130” error and I have to restart the unit via MAC.
While I’m a “veteran” control programmer, I’m new to LabView, and would be very grateful for any pointers on “best practise” for talking to devices via Ethernet, or any specific suggestions for handling multiple PCs talking to a single device.
Thank You.
Tim.
Message 1 of 8
(3,173 Views)
Hi Tim,
Thank you for your post and welcome to the NI forums.
There are lots of knowledgebase articles on our website and you should be able to find documentation for most of our hardware.
There is a good troubleshooting guide for cDAQ Ethernet here (http://ae.natinst.com/public.nsf/web/searchinternal/e67b4e4749f378ff862577270059bd4b?OpenDocument) - it outlines the steps to take to ensure you have a stable a connection as possible. You may have already seen it, but the quick-start guide for your specific device may also be worth consulting for best practices. Are these helpful?
As for using more than one PC - this shouldn't be too much of an issue. I would expect that the resource isn't being closed correctly - when you exit the App on PC 'A', how are you closing off the resource?
Eden S
National Instruments UK & Ireland
Message 2 of 8
(3,137 Views)
Hi Eden,
Thanks for replying.
Our .vi is based directly on the "Network DAQ - Basic Configuration.vi" from the LabView examples.
It reserves the device with the "DAXmx Reserve Network Device" function.
Sits in a while loop, (sending a value using the DACmx wite function when users presses some open/close barrier buttons, )
...until the user presses the Exit button
then calls the "DACmx Clear Task" and "DACmx unreserve network device" functions as it exits.
Really simple application....
...just seems a bit flakey.
Tim.
Message 3 of 8
(3,129 Views)
...sorry, but I can not open the link you suggested.
Message 4 of 8
(3,127 Views)
Sorry Tim, accidentally sent you the internal version, try this - http://digital.ni.com/public.nsf/allkb/E67B4E4749F378FF862577270059BD4B?OpenDocument
OK, the application seems simple enough. I'll check out the example you're basing it on and get back to you.
Eden S
Message 5 of 8
(3,125 Views)
Hi Tim,
I hope the link helped. As for the connection issues - I have looked at the example and as long as you're unreserving the resource correctly there shouldn't be an issue (as you know).
There are a few steps that may be worth trying on this document.
Eden S
Message 6 of 8
(3,098 Views)
Can't get the referenced URL to work. Says no longer available or error in syntax.Smiley Indifferent
Message 7 of 8
(3,042 Views)
Oops! Never mind. Just saw correction in next msg. Smiley Wink
Message 8 of 8
(3,041 Views)
