Best Way to do this array manipulation
I have an array as follows:
61 3 51 5 61.2 3.4 51.3 4.3 61 7 51 4
where the data is in sets of two so array[0] and array[1] make up one data set (61,3) and the next data set is (51,5) then (61.2,3.4) ect. What I want to do is to clean this array up so that any data set where the X values are within some set value, say 1 then they are seen as duplicates and removed, unless the y values differ by more than 1. So for example this set would clean up to
61 3 51 5 61 7
Is there any nice way to do this in labview?
Thanks.
Intern NSWCCD Carderock.
(3,126 Views)
Look at Decimate 1D Array. I think it will do what you want.
Lynn
(3,116 Views)
I tried to use the following VI but it doesnt seem to work, any suggestions? Thanks.
(3,099 Views)
Is this what you wanted?
(3,082 Views)
