Best arquitecture/model to control + datalogging + display
I've been reading a lot of theory, but at the moment for starting my mind goes blank and I don't find the way to solve my problem.
What's the best arquitecture/model to control + datalogging + display???
What I need it's just simple. I need to control one transducer by 4-20mA and another with voltage 0-5V. I need to control an output depending of the value of the 4-20mA transducer, and if the voltage goes above a defined threshold, then it aborts everything.
I'm still new but need this....hope you can help. Thanks in advance.
(2,474 Views)
Hi iapetus2001;
in thsi case I would recommend a mix of two design patterns, first Master/Slave for control and display (use the same loop for both) and Producer/Consumer for datalogging. Here are two examples of both Design Patterns.
https://forums.ni.com/t5/Example-Code/Producer-Consumer-Read-Waveform-Data-and-Write-to-TDMS-at-Two/... Producer/Consumer
https://www.ni.com/en/support/documentation/supplemental/21/producer-consumer-architecture-in-labvie...  Master/Slave
I hope the info is useful
Good Luck!
Francisco Arellano
National Instruments Mexico
Field Systems Engineer - Energy Segment
www.ni.com/soporte
(2,450 Views)
