Best hardware for an application
Dear all
I need to recover a broken furnace from my lab.
The manufacturer does not support it anymore.
I will present the furnace:
- works all time 540 degrees C
- it has a balance incorporated
- it has 2 thermocouples type K
- it has 1 solenoid for door lock
- it has 3 SSR relays for the heat resistors.
I should need:
- now a pc with LB
- a hardware with analog IN (2 for temp, 1 for balance)
- need a signal amplifier for load cell from balance and amplifiers for thermocouples
- a hardware with analog or digital out for lock door, control temp by controlling SSR
 This furnace is for burning a sample in a constant temp of 540C and the time is that between 2 weight we has no weight difference.
The NI6009 should be the right choice?
What are your opinion?
Best
CPalka
(2,122 Views)
Hi Cpalka,
Not at all.
It doesn't handle thermocouples…
I should need:
- now a pc with LB
Use a PLC with some suitable input/output modules.
Or use a cRIO to handle your "works all time" condition…
What is a "pc with LB"?
(2,106 Views)
Hi Knight
The idea at the beginning was to use a PLC with a display window, but it will be another challenge to study and learn....
Idem for cRIO
Pc with labview installed and connected to a bord as NI6009
Best
cpalka
(2,102 Views)
Hi cpalka,
Idem for cRIO
A stone-old USB-based cheap hardware like the NI6009 isn't recommended to control your system IMHO.
What are the safety requirements for such a system?
How much can be harmed (humans and laboratory devices) when something in this system breaks?
(How much is it allowed to cost when that cheap solution breaks?)
Again: to provide some (but not all!) safety measures you should use an "always on" PLC or cRIO…
(2,093 Views)
Hi Cpalka,
How are you?
I would suggest you use US-TC-AI (https://www.mccdaq.com/PDFs/specs/USB_TEMP_TC_series_data.pdf)
I have used it before. All you have to do is to download drivers or whatever that needs to be interfaced with LabVIEW then you should be good to go. Below are how its VIs look like. You have a bunch of options as you can see below.
~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~John 14: 6~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
(2,077 Views)
Hi knight
You are completely right. Safety first.
I worked in the past with omron PLC, but it was many years ago.
I will see.
Best
cpalka
(2,071 Views)
Hi GRCK5000
Seems a good solution to use with labview and a PC.
I will think on that or in the way to use a PLC
Best
cpalka
(2,069 Views)
