Best indexing way for parallel loops with in place element structure inside
@crossrulz wrote:
chembo wrote:
There is one in the In Place Element structure in the second loop with the shift register. Well, long name: Array Index / Replace Elements Border Node. It creates a buffer allocation.
It doesn't make a copy of the data.  That operation is happening in the memory location of that array index.  The Buffer Allocation is likely just a pointer.
OK, this is good to know. Is this statement also true when the size of the array element at this index changes, for example if you add elements to the Y-array?
Message 11 of 12
(1,086 Views)
If there are changes to the array size, then there will be a new memory allocation on the writing of the element.  There is not really any way around that.
Message 12 of 12
(1,082 Views)
