Best option to represent 3D Robotic structure and move only limbs not whole Body
Hi
I am trying to make simple 3D Robot with two legs and I want to move its legs and therefor forward motion of complete motor. I dont want to invlove reverse/forward kinematics.
I know little about following options
Soft Motion
3D Picture Control
loading solidworks vrml file in labview.
Is there anything better than this ??? Can anyone provide links, examples please.....its really urgent
Thanks in advance 🙂
Thanks & Regards,
Kunal Raithatha.
CTD - CLAD (I wish I can take off that A, and maybe use it later to replace D 🙂
Easy Tip :- "To copy an image to a VI icon, drag the image file and place it on the icon
located in the upper right corner of the front panel or block diagram" ...If you know any
more reply back.
(3,516 Views)
More detail please. Are you just going to play a looped 3-d model video? Because you could just make the video somewhere else and play it in labview. Are you trying to use the graphical controls to control the robot or represent current leg positions? Why are you trying to do this in labview?
[will work for kudos]
(3,499 Views)
Well m doing it as a part of my project........Micro Robot which has a Chevron beam exposed to Laser for actuation.
Here is the flow
Laser beam ON  -> Increase in temperature -> Expansion of chevron beams -> Chevron beam pulls the conected shuttle forward -> Shuttle drags whole body forward ->
Laser beam OFF  -> Back to initial temperature -> Back to original beam length -> Shuttle can move only in forward direction -> Body drags legs  ->  forward motion known as Stick Slip phenomenon.
Just see attached Robot structutre Image.
Thanks for replying....Will definately give you Kudos 🙂
Thanks & Regards,
Kunal Raithatha.
more reply back.
(3,492 Views)
Check this out: http://zone.ni.com/devzone/cda/tut/p/id/3170
There is a section about opening VRML files in labview
As far as moving limbs, you would probably have to use 3 vrml files, one for the body and one for each leg. Then you would have to rotate the leg models and stuff. Sounds pretty tricky in labview but if you are good at 3d math it should be no problem... (insert nightmares of calc 3 here).
Support for vrml files list: http://digital.ni.com/public.nsf/allkb/94E716A426FAD46B862575CA005747E0?OpenDocument
Tips for creating a good vrml file: http://zone.ni.com/devzone/cda/tut/p/id/4930
Let me know if thats a good start?
There are some real good examples out there. Once you read those articles, you might start by going through some good examples of 3-d stuff in lab view. Here is one: http://decibel.ni.com/content/docs/DOC-2059
(3,482 Views)
Well as mentioned via first link ...I can select particular part number and play with it ....Play here mean Angular position change of Beam which is not a Translate.vi stuff but if I can control Rotating (approximatiing bending of a beam) that part for particular angle (depends upon temperature change) due to  for particular axis.
If all of the above possible then thats the solution
Thanks & Regards,
Kunal Raithatha.
more reply back.
(3,476 Views)
I can't get into all of the details but can offer some thoughts.
THe 3d picture renders a scene that is comprised of the parts you add. Each part can also have parts added to them and when you apply a trnsform to an object the same transform is applied to the parts. So if you put your model together correctly, moving a leg should result in the knee nakle and foot following it.
Maybe I missed somthing but no Calculus involved just a lot of trigonometry.
Ben
(3,448 Views)
