Best practice concerning .ini file read out
Yup OpenG, or MGI read/write anything works fine for most things.  MGI has a lot better read/write times because they re-wrote their file I/O code to not use the NI INI VIs, but both work more or less the same way.
Message 11 of 12
(1,190 Views)
I wrote a series of posts on databases a while ago. Here is a link to the first one:
http://www.notatamelion.com/2015/01/05/managing-data-the-easy-way/
A database-centric architecture can give you centralized control over configuration without needing to be dependant upon connectivity with a remote DB. This is actually a problem that the database industry had to address a couple decades ago. Try googling "database replication".
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 12 of 12
(1,172 Views)
