So I have been doing some more research and I have another thing I would like for you to try. Again, this would likely be easier if you created a new project that did something very simple using one or two of your variables. However, either way, I am curious what happens if you right click one of your variables and got to properties. Then change the "Bind to:" >> "Project Variable" to "PSP URL". After selecting this, find the proper link for that variable. Once you have done this, check and see if the variable will deploy from an executable. Let me know how this works out.
