Best way to acquire data from both serial port and D/A board in real time?
In my experiment, I have 2 kinds of data: analog and digital. Now, I have to write a programme to acquire both data not only in real time but also in sychronicity. My colleague tried to write a program for this purpose. However, the digital part was failed. For example, the data length found from "data buffer" is correct in the first 10 seconds; however, the format became wrong later.
Is it one program involved two different data acquisition methods?
(2,362 Views)
You need to figure out when the serial port sample occured by some technique and then obtain the equivalent sample from the aquisition board, probably from a circular buffer. If you know the sample rate (pretty implicit really) you can 'cherry pick' the appropriate measurement from the buffer to be synchronus with the serial port measurement.
(2,350 Views)
