07-20-2012 02:31 AM
I'm a new user of labVIEW. can you please tell me how to enable or disable a cluster programatically at runtime. what i'm trying to do is i've created a radio button which has options as : a)X b)Y c)X & Y. so when i select X the cluster X should be enabled and Y disabled, when i select Y cluster Y should be enabled and X disabled and when i select the third option both clusters should be enabled while the program is executing. I have used case structure and functionally this happens. i only want that it should appear also that this is happening. If possible please help.
07-20-2012 02:57 AM
Hi shalini,
Can you upload your VI?
07-20-2012 03:38 AM - edited 07-20-2012 03:42 AM
Here is my vi
07-20-2012 03:43 AM
07-20-2012 03:53 AM
What you really mean?For me it seems to be working.What all things you are trying to achieve?Your Tab control seems to be in a disabled state.See the VI that I have attached and explain your problem more clearly.
07-20-2012 04:15 AM
The tab control was disabled by mistake. As i had written earlier, it is functionally correct, what i want is when i select X, i want the cluster Y in the free running tab to appear as it does when "disable n grayed". Is it possible to do so??
07-20-2012 06:37 AM
Found the solution. Thank u anyways.![]()
07-20-2012 06:42 AM
Hi shalini,
Good! Please post the VI.Let I have a look at it.Iam not getting exactly what you are trying to achieve.
