Best way to implement a config ini reading sequence?
If you are interested in a UI for modifying options within the INI file, check out this toolkit released by NI.  It's basically the same interface you see when editing the LabVIEW options.  It may be a bit overkill for some applications but it's still worth the effort to review the code and maybe find some inspiration inside.
Options Dialog Framework
aputman
Message 11 of 12
(494 Views)
Thank you very much Gregory. I will consider that approach.
Message 12 of 12
(477 Views)
