Best way to store historical data
Hello:
I'm currently developing an application that monitors some phisycal variables such as temperature and differential pressure in different locations. I also must do historical datalogging of the values read so the user can generate reports of the historical data. What is the best way to save the data? I was thinking about using and SQL-based database and use a table for each variable, an make some maintenance on the database after certain time to avoid it getting too big, but I'm opened to any suggestions Smiley Wink
Thanks in advance!
Robst
Robst - CLD
Using LabVIEW since version 7.0
(3,437 Views)
Just my usual reply to this kind of question: use the DSC Tag Engine (or it's LV 8 equivalent). IMO this is the most easiest way to store historical data if you're using LV!
Cheers,
    Carsten
(3,421 Views)
Use the Citadel database inside the DSC engine. It automatically handles file sizes when they get too large.
(3,413 Views)
Hello:
Thanks for the advice... but I'm afraid we do not own DSC. I know DSC is a great option, but for this proyect it is not an option. In this situation, Which is the best way to store historical data?
Regards
Robst
Robst - CLD
(3,400 Views)
There might be an option to install just Citadel and use another method to get data into the database.
(3,393 Views)
Hello:
I've been looking for a way to install just Citadel with no success. I've read that it only ships with Lookout and DSC, so I guess it can't be installed without one of them. Si, if this is true, Do U know another option for doing datalogging?
Thanks in advance
Robst.
Robst - CLD
(3,363 Views)
