Better way to check if VI is dynamic dispatch?
I'm doing a bit of VI scripting, to create a child class of a given parent and overriding selected dynamic dispatch VIs. To create a profile of a class library I am iterating through all the VIs and checking the connector pane to see if it has any dynamic terminals. I'm sure there is a smarter method....
_____________________________
- Cheers, Ed
(2,922 Views)
Accepted by topic author yenknip
If you have a reference to the class library, you might be able to use the "DynamicMemberVIs" property (There is also a "StaticMemberVIs" property).  I haven't tried using this myself, so I cannot guarantee it will do what you need.
Chris M.
(2,912 Views)
Well that was well hidden 🙂
- Cheers, Ed
(2,888 Views)
