Better way to wait for serial data?
I have a device that does not respond to any sort of query but rather spits out a serial data stream every five minutes under normal conditions and every 30 seconds if there is any alarm conditions.
I am working in a vi to capture this data and have a loop that waits for serial bytes. This vi seems to bog down my computer and makes it usless to do any other tasks while I am running this test. I am guessing because it is constantly checking the serial port?
Is there a better way?
=== Engineer Ambiguously ===
(4,719 Views)
While loops (of any type) without any delay in them will cause this. If you simply put a msec wait in there it should improve things quite a bit. You probably don't need to check more often than every 250 msec or so.
(4,708 Views)
I don't know if this helps but this is what I do.  I have a program that runs a main while loop and I have an external while loop that just monitors the serial port.  When data appears in the buffer it reads the buffer until all data is input.  Then it signals a control called read buffer and the main vi gets the signaled data and performs a function on it.
(4,704 Views)
try using events
Message Edited by James R on 03-30-2007 11:40 AM
- James
Using LV 2012 on Windows 7 64 bit
(4,703 Views)
Oh my    Using Events is way beyond my abilities.
Last training I had for Labview was entry level LV 5.1
Just a couple months ago we jumped from LV 5.1 to LV 8.2.Smiley Surprised
I added a ms wait as suggested and it seems to work better that way.
(4,682 Views)
