Bezier curve app
Hi everybody,
I'd like to make an app to make Bézier Curve :
I want to change coordinate of point from the graph (with the mouse) and to check the way it changes the curve.
The challenge is that to find a easy way to reasign coordinate with mouse clic.
Is anybody did that before or have an idea to do it ?
In the other hands, I want to dump datas in MatLab what's the most elegant way ?
Many thanks
(4,507 Views)
Ok I made the GUI and I found the algorithm in order to make a bezier curve : De Casteljau algorithm
I not clever to understand pseudo code, someone can help me ?
struct point
float x;
float y;
// 4 points define the bezier-curve.. These are the points used
// for the example-images on this page.
point a = { 40, 100 };
point b = { 80, 20 };
point c = { 150, 180 };
point d = { 260, 100 };
// simple linear interpolation between two points
void lerp (point &dest, point &a, point &b, float t)
dest.x = a.x + (b.x-a.x)*t;
dest.y = a.y + (b.y-a.y)*t;
// evaluate a point on a bezier-curve. t goes from 0 to 1.0
void bezier (point &dest, float t)
point ab,bc,cd,abbc,bccd;
lerp (ab, a,b,t); // point between a and b (green)
lerp (bc, b,c,t); // point between b and c (green)
lerp (cd, c,d,t); // point between c and d (green)
lerp (abbc, ab,bc,t); // point between ab and bc (blue)
lerp (bccd, bc,cd,t); // point between bc and cd (blue)
lerp (dest, abbc,bccd,t); // point on the bezier-curve (black)
// small test program.. just prints the points
void main (void)
point p;
for ( int i=0; i<1000; i++ )
float t = (float)i/999.0;
bezier (p,t);
printf ("%f %f\n", p.x, p.y);
Many thx
(4,494 Views)
Hi Doyon,
attached you will find a LV6.1 version of your "pseudo" code...
(4,479 Views)
Many thanks,
I was able to did it... finally
Take a look
Message Edité par Doyon le 11-23-2007 12:42 PM
(4,458 Views)
Hi Doyon,
did you attach anything here?
I changed the demo a little bit to allow playing with it Smiley Happy
(4,429 Views)
